DAQmx.rc is not found on another computer
i created a VI that uses NIDAQmx 17.0 which is working fine. Then i copied it on another computer and there i get errors.
In Teststand the error says "The driver needs a VI or tookit component that is not found. Missing resource file "daqmx.rc".
In the broken VI for example the proprties DAQmxChannel->CO.Pulse.Term is not available.
What do i have to install?
Thanks for help
(3,304 Views)
Hi One,
you should install DAQmx17 on that other computer…
(3,296 Views)
yes it is installed.
Attached a screenshot of NI MAX of noth computers.
Or is there an option to add "Labview support" during installation?
In labview the icon-folder in rightclick -> Measurement I/O -> NI-DAQmx is not available in the "not working" computer.
(3,287 Views)
Hi One,
Did you install LabVIEW after you installed DAQmx?
You need to install in this order: first LabVIEW, second DAQmx. Then the DAQmx installer will include the "LabVIEW support" while installing…
(3,265 Views)
Hi @GerdW,
i reinstalled NI DAQmx and after this the VI was executable in Labview and in Teststand.
Then i uninstalled Labview as the the VI should be used in Teststand with only Labview Runtime.
But now it is no more loadable in teststand and the error is:
Error Code modules must be able to load General Module for Step 'xxxxxxxx' not Loadable. Failed to load VI 'C:\xxxxxxx.vi' in the LabVIEW Run-Time Engine version '14.0.1f7'.
LabVIEW: The VI is not executable. This error may occur because the VI is either broken or contains a subVI that LabVIEW cannot locate. Select File>>Open to open the VI and verify that you can run it.
VI Path: C:\xxxxxxx4.seq Seq["xxxxx"].Main["xxxxxx"].TS.SData
Then i reinstalled NI DAQmx again (i thought the uninstall of Labview perhpas also removed some files of DAQ installation) but the error above stays.
What can i do to make it runable using only the LV runtime?
(3,213 Views)
Accepted by topic author OnlyOne
(3,152 Views)
