DAQmx or Express-VI to contin. view measurements and record pre and post trigger
Hello. I'm fairly new to LV and my task is as follows:
Measure and continuously display analogue data with a PXI 6052E and, upon a failure trigger, record pre and post trigger data (2 secs @ 1 kHz) to a file.
The setup is to run several units at the same time, which can fail individually and with individual triggers. Moreover, after failure, they may recover, so it must be multiple triggerable, to record with timestamp into one file per DUT.
Any help is very much appreciated
(2,493 Views)
1. As I understand it you have only 2 digital Triggers at this card.
2. Try to look carefuly and change parameters at "Acq&Graph Voltage-Int Clk-HW Trig Restarts.vi" example or "Cont Acq&Chart Samples-Int Clk-Pause Trigger.vi" example.
Hope it Helps...
The Bush-Man
(2,477 Views)
