DAQmx issue
Hello,i have a problem with a labview18 program.When I open it I get an error for DAQmx write.I tried to reinstall NI-DAQmx(18.6) but it still not working.Any ideas?
(1,449 Views)
For us to provide useful help, please do the following:
  • Open MAX, click the Software Tab, and take a screen shot of the installed NI Software on your PC.  Please state if you are running 32-bit LabVIEW or 64-bit LabVIEW (I'm running 32-bit, but MAX doesn't seem to show this to me).
  • If you are developing using LabVIEW Project, compress the folder containing the Project and its VIs, and attach the resulting .zip file.  If you are just writing a single VI, attach the VI.  We cannot "debug" a picture.
  • If LabVIEW is properly installed (which is probably not the case), you should not need to "reinstall NI-DAQmx (18.6)".
(1,409 Views)
