DAQmx base error on Windows Mobile Emulator
Hi
Im using NI-DAQmx base to plot values from a USB-6008 in a graph. Im currently deploying my app to a Windows Mobile 6 Emulator because i havent received my PDA yet, but when the program is executing on the emulator it quits with the message: "Unable to start application. Error code: 1".
I've tried using a Windows Mobile emulator 5 instead but same error. I've also tried running the example programs for DAQmx base like "Acq&Graph Voltage-Int Clk.vi" but also same error.
Does anyone know if im doing something wrong or if its just not possible to use DAQmx base on a emulator?
Thanks in advance
Dennis Francek
(3,322 Views)
Hi Dennis,
Is it a Windows Mobile error or a LabVIEW error?
Could you post a screendump of the error message?
What version of DAQmx Base are you running?
Windows Mobile 6 is not supported by DAQmx Base 3.2 which is the latest.
Eirikur Runarsson
(3,301 Views)
It could be both i guess..
Im running version 3.2.
Have a look at the screendumb and see if you get something from it.
(3,296 Views)
Could you share your code so I can try this at my site?
What version of LabVIEW are you running?
Eirikur Runarsson
(3,242 Views)
Heres the VI i made. I run it from a Windows Mobile 5.0 Pocket PC emulator and thats when it just quits with above error.
My version of Labview is 8.6.
(3,195 Views)
