06-29-2006 01:58 PM
06-30-2006 01:49 PM
05-26-2008 01:56 AM
05-26-2008 10:35 AM
05-26-2008 07:08 PM
05-27-2008 11:12 AM
05-27-2008
01:35 PM
- last edited on
02-01-2026
04:38 PM
by
Content Cleaner
Hi Teresa,
On a pda target you cannot use the DAQmxbase Create Task or Create Channel VI. In order to setup your data acquisition task you must use the NI-DAQmx Base Task Configuration Utility. This utility can be found in LabVIEW under Tools >> NI-DAQmx Base Task Configuration Utility. You can create your PDA DAQ Tasks in this utility. Some more information on this can be found in the KnowledgeBase article, NI-DAQmx Base Task Configuration Utility Does Not Show PDA DAQ Device. Once you have your tasks setup in the utility you can reference them by wiring a string constant with the name of the task into the task/channels in terminal of the DAQmxbase Start Task VI. Please let me know if you have any questions.
05-27-2008 08:50 PM
Dear Nathan
Thanks for your time answering my questions. I have follow your instructions. However when I connect the usb6008 on my PDA(fujitsu siemens loox 830) and run the aquisition program, it shows me the error: Visa GetProperties Error code: -1073807343. Furthermore another question, why when i connect the USB6008 on my PDA, the led´s card blinks faster and weaker than the PC? is it normal?.
I hope you can help me..Thanks a lot...
teresa
05-28-2008
05:37 PM
- last edited on
02-01-2026
04:38 PM
by
Content Cleaner
Hi Teresa,
Error -1073807343 is caused when no USB device is connected to the PDA. This information can be found in the KnowledgeBase article, Errors with USB and NI-DAQmx Base on PDA. It may be that your PDA’s USB port does have hosting capabilities needed to control the USB-6008. Your PDA must have the ability to act as the master USB device. I was not able to find any technical specifications for your model PDA. In addition to this the PDA must be able to provide enough power for the USB-6008. Typically the USB-6008 uses 80 mA. The maximum it uses is 500 mA. This information is in the NI USB-6008/6009 User Guide and Specifications.
05-28-2008 06:31 PM
Hi Nathan,
Thanks a lot. Greetings
teresa
