DAQmx 19.6 not working with 2019
The DAQmx was in a newly created LV2019 folder inside my LV2013 folder. The VI's are fine and have worked for many months without issue until this DAQmx disappearing act.
I now have another issue. My Development LV2019 seems to be working fine when I am on my machine. All of the VI's are complete and I have a clean arrow. When I generate an .exe for our production tester, and the .exe is run it comes up with a broken arrow. When I look at it to debug all of the DAQmx VIs are missing. It's like the "build" isn't including the DAQmx information. Does that point to anything?
Message 11 of 14
(1,132 Views)
If you have a LV2019 folder inside a LV2013 folder, then it sounds like LV2019 installed wrong, or maybe more likely somebody dragged and dropped that folder with a heavy hand on the mouse into the LV2013 folder while looking at Program Files (x86)\National Instruments.
That could certainly cause a lot of problems.
For your production tester, did create an installer for your exe?  Did you include Additional Installers like DAQmx with Configuration Support, or at a minimum, the DAQmx 19.6 runtime?
Message 12 of 14
(1,116 Views)
The run-time is already on our non-development stations. I did not create an installer. I will have to check with the production people this afternoon about what all is on those machines.
Message 13 of 14
(1,105 Views)
Accepted by topic author ChrisMusk
I ended up doing a complete uninstall of all things NI and reinstalling LV2019. I have hod no issues since. I hate that I had to drop back and punt, but it worked.
Message 14 of 14
(1,081 Views)
