DAQExpress installation problem (DAQmx driver missing)
I have successfully installed LabVIEW 2018 on a laptop running Windows 10 Home. LabVIEW Measurement & Automation Explorer has successfully detected a NI USB-6210 datalogger connected to one of the laptop's USB ports.
I now wish to install DAQExpress on the same laptop.
I disconnect the USB-6210, reboot the system and run ni-daqexpress_4.1_online.exe. DAQExpress installs (in part, at least) but I get the following message when I start up the application:
So I then try to reinstall DAQExpress but the process aborts with the following splash screen:
If I click on 'Try Again' the installation process keeps looping back to the above screen.
Please can anyone suggest a possible solution?
(2,780 Views)
As a rider to my previous message, here is the installed software reported by LabVIEW:
(2,776 Views)
Did you ever find a solution to this? i have the exact same problem currently.
(2,254 Views)
