DAQCard-700 causes HP ze5200 w/XP to hang.
A DAQCard-700, a used and working one, causes the new HP pavilion ze5200 with Win XP Pro No(5.01.2600 sp1) to hang when Test Resources or Test Panel is run in MAX(2.2.3010). Updating NI-DAQ 6.9.2 to 6.9.3sf3 didn't help. Do anybody run DAQCard-700 under Win XP successfully?
(2,538 Views)
Yes, the DAQCard-700 has been used under Windows XP and has worked. One thing you should check is whether Windows XP is using the native Windows PCMCIA socket driver.
If they aren't uninstall the socket driver that is being used and install the native one from the Windows installation CD. I hope this helps.
Todd D.
(2,538 Views)
