DAQAssistant cannot be found by labView
DAQ Assistant does not show up under "Express" on the functions palette. Programs that had previously used it now show the error "Driver or toolkit component missing, This VI needs a driver or toolkit component that is not found. Missing resource file daqmx.rc".
I am running LabVIEW 2018 SP1 (32 bit). I have uninstalled NI-DAQmx and re-installed it, currently on version 20.7, which is compatible with my version of LabView. These are visible in NI MAX and the Package Manager, as shown. The driver has been installed after LabVIEW.
(3,129 Views)
Hi Gubenator,
did you install the "DAQmx support for LabVIEW2018" as suggested by your error message?
(3,124 Views)
Thank you for your reply-- I'm not quite sure what you mean. The knowledge base for the issue is in the link below. I have the driver downloaded, and the driver version is supported by LabVIEW 2018. The installation order is correct, and the full drivers are installed. Is there something I've missed?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019NnISAU&l=en-GB
(3,098 Views)
1. Open NI Package Manager
2. Under INSTALLED tab. Uncheck Product Only.
3. Search for daqmx.
4. Make sure NI-DAQmx Support for LabVIEW is installed. If it is not, run the NI-DAQmx installer again,
https://tmesystems.net/
(3,057 Views)
I have NI-DAQmx support for Labview 2019 (64 bit) installed, and I am running 2018 32 bit. This doens't change when unistalling and running the installer agian. Is there a way to force it to download the 32 bit version?
(3,049 Views)
Accepted by Gubenator
Click-on the setting icon on the top right and check all options.
Go to PACKAGE tab, search for NI-DAQmx Support for LabVIEW 2018 and install it.
(3,045 Views)
Solved! Thank you so much, you've really helped me here.
(3,039 Views)
