DAQ reading zero intermittently
I am using 3 analog inputs of a DAQ USB-6009 to monitor and record temperatures of my system.  This VI runs continuously performing 1 read per second and periodically saving values to file.  Everything works great for a couple weeks, or even a few months, until the DAQ reads suddenly have a value of zero.  unpluging the DAQ and plugging it back in solves the problem.  As such, I am assuming it is due to a power cycle of the DAQ or perhaps the USB communication being refreshed that I receive the correct values again.  Any ideas on how to test for the cause of this issue or some preventative steps I can take?
I was thinking closing and re-establishing communication at the end of each day might help.
Oh, and I'm using LabVIEW 2010 on Windows 7.
(3,679 Views)
Accepted by pjr1121
Turn off the "power saving feature" of Windows 7 where it randomly turns off your USB hub.  Go into the Device Manager and go to the USB hubs and then into the power settings.
(3,672 Views)
Since I had the Windows power management options turned off I hadn't considered separate power settings for the USB.
(3,664 Views)
