01-11-2010 04:45 AM
Hi
I am not able to open the DAQ assistant in labview. I am using Labview 7.1 and IN-DAQmx 8.9.5.
I have read the forums and tried uninstalling and installing the drivers, and when that didn't work, I uninstalled all the drivers as well as Labview and installed Labview first and then the drivers, but I still have no DAQ assistant.
I am connecting a USB-6009.
Any help would be much appreciated.
01-11-2010
05:03 AM
- last edited on
09-27-2026
11:29 AM
by
Content Cleaner
01-11-2010 05:13 AM
Yeah, I guess I kinda didn't want to notice the fact that Labview 7.1 was not listed when I installed DAQmx.
Thanks for the help.
Herman
01-11-2010 05:36 AM
I noticed that DAQmx 8.9 supports Labview 7.1, but can't figure out if it supports the NI USB-6009. Is there a driver that supports both Labview 7.1 and the NI USB-6009?
Herman
01-12-2010
09:45 AM
- last edited on
09-27-2026
11:30 AM
by
Content Cleaner
Hi Herman,
DAQmx 8.9 does in fact support the 6009.
The best place to find out if a specific version of DAQmx supports your hardware is in the readme. Here is a link to the DAQmx 9.0 readme, you can typically find readme links on the driver download page.
Best Regards,
01-14-2010 06:22 AM
01-12-2011 05:43 PM
I'm unable to get DAQ Assistant with Labview 8.2 and device pci-6220. What's going on???
01-12-2011 06:27 PM
Have you downloaded the DAQmx drivers?
Alan
01-12-2011
06:35 PM
- last edited on
09-27-2026
11:31 AM
by
Content Cleaner
Oh I see now, you have posted this question in multiple places with "other" informaation. In one post you say you have downloaded 9.2.2 DAQ and are using LV 8.2
Here is a compatability list, you down loaded the wrong drivers.
https://www.ni.com/en/support/documentation/compatibility/16/ni-daqmx-and-labview-compatibility.html
Alan
