DAQ assistant does not read samples
Hi, Good mornig.
My name is Jorge.
I am engineering student and it is my first time using labview. I Can´t solve the following problem about DAQ and maybe you can help me.
The problem is the DAQ assistant don´t show me the samples acquired when i set the acquisition mode: "continuos samples"
But, as we see in the second image the samples are arriving to the DAQ assistant (Temperature=17,97)
On the contrary, if i set the acquisition mode: " 1 Sample (On Demand)" everything works perfect.
If anyone knows how to show samples in the acquisition mode: "Continuos Samples".   I would be very grateful! 🙂
(2,620 Views)
Hi Jorge,
what about some error checking/handling?
Are there any errors in "continuous mode" from your DAQAssistent?
Generic advice: don't stick to the DAQAssistent ExpressVI, try to switch to DAQmx functions as soon as possible…
(2,609 Views)
I have no error.
(2,601 Views)
Hi Jorge,
until now you failed in providing information on:
  • your LabVIEW version
  • the installed DAQmx version
  • the hardware you are using
  • attaching the VI
Mind to share all that information?
(2,583 Views)
yes GerdW, of curse:
-my labview version is 21.0 (64bit)
-NI-DAQ mx driver version 21.0.0f164
-I´m using a chassis NI cDAQ-9178 with a data acquisition card NI-9213
i have attached the VI.
thanks for everything.
Jorge.
(2,528 Views)
