DAQ and microphone
Hi all,
I am using NI USB-6009 and I want to use microphone to get the sound input
How can I connect the microphone to the DAQ?
can i use a wire and connect directly to the microphone?
plzz help me with the problem
i'll attach the spec of the mic i am planning on buying
(3,497 Views)
The problem is that the microphone needs to be powered (+15V to +48V).  This is done on the signal lines via Phantom Power.  Useful for sound systems.  Not so much for DAQ setups.
What you may be able to do use use a power supply to get the voltage on the signal lines and then use a capacitor in series with the DAQ.  The idea here is to AC couple the DAQ so that it only sees changes in voltage, not the DC power.
(3,463 Views)
thanx for the reply:)
so, you mean that i have to use power supply and capacitor to power the microphone?
(3,422 Views)
Why not plug your microphone into your PC's Sound input and use the Sound Input VIs that ship with LabVIEW?  Let your PC do the acquisition for you (and use the USB 6009 for other things).
(3,400 Views)
