DAQ Assistant from a LabVIEW block diagram
Hello everyone,
Could anyone help me to know how I launch the DAQ Assistant from a LabVIEW block diagram when the express does not show it?
Thank you
(1,949 Views)
Hi Sergio,
search for the title "DAQmx 10 functions" and pick the first search result (at least when I search for that) to learn the simple usage of DAQmx without using any Express VIs...
(1,916 Views)
Hello GerdW,
Thank you.
I actually I found the problem. It was related to the DAQmx software. When I had the problem, I uninstalled the LabVIEW software hoping that was the problem but it was not. After that, I installed the LabVIEW once and the problem was there. But, the daqmx software was not installed before so, I decided to installed again and then it appeared!
It looks like package manager does not like the daqmx software in the same package.
Thanks anyway.
SergioMRendon
(1,854 Views)
