DAQ Assistant error
I am using an NImyDAQ. I have attached audioInputRight to a Knowles microphone (Datasheet attached). I have used the DAQ assist template on LabView and try to run it. But I get a DAQ assist Error.
Im not sure how I need to adjust the parameters to get it to work.
Error -200077 occurred at DAQ Assistant
Possible Reason(s):
Requested value is not a supported value for this property.
Property: AI.Min
You Have Requested: -10.000000
Valid Values Begin with: -2.000000
Valid Values End with: 2.000000
Channel Name: Voltage
My project: It involves using three of the microphones to perform adaptive beamforming to improve the SNR. I am an undergraduate on this research project from TAMU. I would appreciate any help.
Thank you and Regards,
Sharath Prasad
(3,190 Views)
Accepted by SharathPrasad
The error message seems to pretty clearly tell you what is wrong.  You tried to set your analog input range so that -10 was the minimum, but you can't go lower than -2.
So set your analog input range to be -2 to 2.
(3,184 Views)
Thank you, I fixed that.
(3,170 Views)
