DAQ Assistant Continuous Data file
Hello.
I am using the DAQ Assistant to collect continuous analog data and write to measurement file.vi to write the file to a tdms file. I want the file to contain a continuous record of the analog data, but the export file contains the data separated into blocks. Does anyone have a suggestion for generating a file with one continuous data stream? I have attached my code and a sample export file.
Thank you.
(3,577 Views)
Accepted by Miller37
Hi there,
Are you referring to the separate tabs or separate files?
If separate tabs:
Have you tried setting your Write to Measurement File to output one header only as opposed to one header per segment?
If separate files:
You can set the Write to Measurement File to append to a previous data file. Hope this helps!
Ingram
Ingram | CLA
(3,558 Views)
Problem solved. Thank you.
(3,553 Views)
