DAQデバイスのPCへの登録について
以前から,PCI-6221のDAQデバイスを使ってLabVIEWでの計測を行っていたのですが,先日PCが故障し買い替えることになりました.
前使っていたPCは起動できなくなってしまったのですが,PCの登録を解除する方法はありますか?
もしくは,前の登録を解除しなくても,新しいPCに登録をする方法はありますか?
また,PCI-6221の仕様を見ても分からなかったのですが,最近のPCやOSには対応しているでしょうか?
よろしくお願いします.
(580 Views)
Accepted by topic author moriTK
@moriTK wrote:
I have been using the PCI-6221 DAQ device to perform measurements with LabVIEW, but the other day my PC broke down and I had to buy a new one.
The PC I was using before can no longer start. Is there a way to unregister the PC?
Or is there a way to register on a new PC without canceling the previous registration?
Also, I couldn't tell from looking at the specifications of PCI-6221, but is it compatible with recent PCs and OS?
thank you.
You don't have to deactivate the license on the old PC if it is no longer accessible. You can active your license on the new PC straightaway.
According to NI Hardware and Software Operating System Compatibility, PCI-6221 is still supported in the recent version of NI-DAQmx driver.
https://tmesystems.net/
(540 Views)
