Customizing string control looks
I want to customize a string control and make it look something like this:
Someone please tell me how can I do this or something like using an imported image and set it as a decal (as we do to customize buttons) for string control and make the corners round.
Thanks in advance.
Best Regards
Ankit Yadav
(4,163 Views)
Accepted by topic author yadavankit9999
Hi Ankit,
Use a classic simple string control and paint it transparent. Then place it over your graphics…
Is there anything special about this image? Do you need any special behaviour?
(4,132 Views)
Thanks for the idea, GerdW
I just want to make my front panel more attractive and at the end of the string control, I can create a button(with string control itself) using event structure and get the coordinates of that part, and then using case structure and all.
I know the rest of the part but can you please explain a little about painting something transparent. The steps to do so will help a lot.
Thanks for your help
Best Regards
Ankit Yadav
(4,103 Views)
Edit: Ignore my comment. Sorry
(4,088 Views)
Hi Ankit,
Use the paint tool (brush) and select "transparent" color. Now paint the string control! (I recommend the simple classic string control as it is much easier to paint...)
(4,063 Views)
Thanks for this again, GerdW
Just help me with one last thing, that how can I import an image in the front panel such that I can control its position using property nodes as we can control for string controls. I tried to simply drag it to the front panel, but then I was unable to control its position.
Thanks in advance
Best Regards
Ankit Yadav
(4,044 Views)
Hi Ankit,
use a 2DPicture indicator. Or customize a button to show your image...
(4,033 Views)
