Customizing gauge in LabVIEW
Hello All,
I want to develop a gauge in LabVIEW with a range of 0 to 100. The gauge value will be controlled using a numeric input. Based on the input value, the gauge should be dynamically filled with color up to that value, while the remaining portion should stay white.
How can I implement this functionality in LabVIEW?
If possible, could you provide a sample LabVIEW program or step-by-step guidance to achieve this?
(1,157 Views)
Hello All,
(1,155 Views)
Hi sasimitha,
You could paint your gauge using a 2DPictureIndicator:
  • draw a "white" circle"
  • draw a circle section, using a thick "color" pen, based on the percentage value
  • handle transparency of your 2DPictureIndicator
(You could embed all this into an XControl, so you have an "ordinary" numeric terminal in your main code… 😄 )
(1,145 Views)
Here's something I built about a decade ago just as a quick experiment. The code isn't good, since it was just a quick test, and it doesn't do exactly what you want, but it should give you a direction.
___________________
Try to take over the world!
(1,141 Views)
Qestit Systems
Certified-LabVIEW-Developer
(1,083 Views)
