Customizing a graph, can only shrink graph area
I am running into an issue where my Y scale on a XY graph is sometimes too far from the graph, or too close and overlaps the graph area. If I customize the graph I can only shrink the graph area, and it seems to shrink a bit every time I try to change it. See video
(1,363 Views)
Hi StevenD,
Did your graph originally appear like that when you first created it from the function palette? Because I tried to edit mine from Advanced>Customize it worked well and I can size it to be near/far from my  Y scale.
Maybe you could try
1. Right click your graph on front panel > Properties > edit Position under Apperance
OR
2. Right click > Replace with a new XY graph(will not affect your code)
These are the posibble solutions I could think of right now.
Fiona, NI
(1,274 Views)
Graph scales don't behave well once they are tempered with.
You could try an Advanced>Reset Scale Layout.
Note that might reset more that you want, and it might not reset what you want. So, save (and use SCC).
(1,270 Views)
