01-11-2016 12:07 PM
Hello everyone, I have a question: how can I insert words and numbers into the same array?
I create a VI that measure the temperature with an external instrument, and put the data into an array, which is saved.
Every row is a Thermocouple and every column is a measurement, but there is only numbers!!!
I would like to have the first column with the name of channels and fist row with the name of measurement.
I had create an excel of example to explain my wish (Cattura.PNG).
Thank you to everyone who will help me
01-11-2016 12:14 PM
I suggest to create an array of strings, and insert numbers there converted to strings toghether with headers.
Arev
CTO | RAFA Solutions
01-11-2016 12:29 PM
Sorry but I don't think to know how do what you said. Can you explain how create an array of string? Do exist a tutorial that I can follow?
01-11-2016 12:36 PM
You can use "Number to Fractional String" function available in String -> Number/String Conversion palette. I have shown an example below.
After you can add your headers to the array and write it to the spreadsheet.
01-11-2016 01:41 PM - edited 01-11-2016 01:42 PM
Hi Enrico,
use a table and set row/column headers as needed…
(You still need to format your numbers as a table is just a 2D array of strings - but it eases the data handling as row/column headers are not part of the data.)
01-13-2016 08:35 AM
Thank you to everyone.
GerdW I've tried to do how you said me but now it write only the last measurement in the first column.
Also the headers are visible only in the Front pannel, they don't appear in my excel file.
01-13-2016 09:15 AM
Hi enrico,
Yes, you have programmed it that way! Your inner loop only outputs values of the last iteration…
Why do you need to transform the data into a matrix?
As I wrote before: "it eases the data handling as row/column headers are not part of the data."
You need to write the headers seperately into your file - they are not part of the table data…
01-13-2016 10:14 AM
1) Why do you need to transform the data into a matrix?
Because I'm tested a thermal camera. I would put the number of measurement that the VI had to do ("numero misure"), the time between two measurement ("Secondi tra una misura e l'altra") and at the end I would a matrix with all the data (every column a measurement and every row a channel), and I would that this matrix will be save in a excel file.
2) ok, I didn't read well, sorry
01-13-2016 10:17 AM
You can insert required headers as column and row to the converted to string array, as in the image below.
01-13-2016 10:50 AM - edited 01-13-2016 10:58 AM
arevhamb thank you thank you thank you. You have risolved my ploblem.
