Custom Scroll Bar Width Does Not Save
Hi everyone,
I was checking out LabVIEW 2009 Bug Fixes, They mentioned the below Issue as fixed. So I have a doubt whether this scroll bar  belongs to table/multi column list box?
485433TOG6U3ACustom Scroll Bar Width Does Not Save
When I tried this in 2009, it still have problem, and NI Application engineer said that it is still pending in 2009 also.
So I would like to know in which control this scroll bar issue is fixed?
http://zone.ni.com/devzone/cda/tut/p/id/9510
Anil
Anil Punnam
CLD
LV 2012, TestStand 4.2..........
(3,771 Views)
Hi Anil,
I believe you can add the following token to the Labview.ini file: autoResizeScrollbars=false.  However, the bug is still not listed internally as fixed.  However, I believe that token should work.
Jared S.
Applications Engineering
(3,741 Views)
Arrgh, I first reported this behavior (well, alright, I was using a table control/indicator, not the MCL) back in LabVIEW 8.0.  The discussion thread can be found on the LAVA forums, starting September 14, 2006.  In that discussion, Scott Menjoulet and jhoskins seemed to be able to work around it with the "custom control in a project fix", but I could never get that to work, at least not when I built the custom table into an executable.  I filed a bug report on the next beta cycle, but I can't find my old bug reports/CARs online anymore.
But I'm reasonably certain it's been an identified bug since 8.5.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
(3,535 Views)
Hello Dave,
Correct, the workaround fix is still to set the LabVIEW.ini config token "AutosizeScrollbars" to "FALSE", and LabVIEW will not resize the listbox's scrollbars on load. And then to open a VI containing a Custom Control from the hard drive rather than through the project results in different appearance of the custom control.
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
(3,499 Views)
