‎08-31-2021 02:21 AM
Thats what I was looking for, you helped me solve my Problem. I was just following the average tutorial how to customize a control, most of them just tell you to make a type def out of it.
@crossrulz wrote:
@billko wrote:
@crossrulz wrote:
@Philipps wrote:
I created OK Buttons and hooked them up to my event structure, but when i changed one of them to a custom button the connection broke.
Stupid question: Why did you make a Boolean a type def? I would change that to a control so that the button is no longer getting its value type from another file.
If it's been customized, why not?
Because it is still just a Boolean. Type Defs are really made for custom data types, which I generalize down to enums and clusters. When you just want a special looking button, you make the ctl a control.
‎08-31-2021 02:34 AM
After you guys helped me understand how to make custom controlls I found this in the LabView help and that was what I was looking for the whole time.
https://zone.ni.com/reference/en-XX/help/371361R-01/lvhowto/custmzng_cont_ind_fp/
‎08-31-2021 09:17 AM
My impression so far was that you had problems with events, not with customizing a control. Two very different things!
‎08-31-2021 09:22 AM
I had problems with my event structure because of the type def booleans, but I actually dont need to type def them to customize them. I just found some bad advice when I looked for solutions online how to change button appearences.
