Curve Fitting Of a Frequencie Response
HI Richard..
is possible for you to post the .vi for the 2010 version??
Nigeltorque
Message 11 of 15
(674 Views)
Anyway Altenbach.. i try to explane what i am doing with this .vi.
I have to modeling a non-linear dynamic system.. it could be scomposed in a linear component and a non linear component.
To charachterize the linear part i send to my dynamic system (vacuum tube amplifier) a low-level signal with frequencie 10 Hz - 25000 Hz as input and see how it respondes. I take the frequencie response curve, normalize it to 1, make 1/x and the formula i found fittind this curve is the TRANSFER FUNCTION of the linear component..
So i just do all this to find out the TF of the linear component of my amplifier to charachterize it; in the attachment you see how is possible to "divide" a DUT (device under test) with a Black Box approach..
Hope i was clear...
P.S i think to find out the TF it will be more easier to use the System Identification Tool that is full of Bode and TF vi, but i don't have it... and i can't download the evaluation module cause i use Labview Student Edition 2010..
Nigeltorque
Message 12 of 15
(669 Views)
Attached is the 2010 version of the vi I posted before.
Richard
Message 13 of 15
(656 Views)
Hi Richard
thanks for your .vi it was very useful. But i still have a question.. how is possible that if i just normalize the signal to 1, and do 1/x is impossible for me to fit new curve?? It's just the reciprocal, it's a simple curve but it's impossible to fit.. do you know why?? how is it possible?? i have to use the polynomial fit .vi because i need to specify the polynomial order to use the math equation in the right way..
In the attachment there is the final .vi; if i find the way to fit that curve my vi will be complete!
I will be very grateful to anyone who could help me..
Nigeltorque
Message 14 of 15
(649 Views)
You normalize between zero and 1, so at least one point is zero.
Once you do a 1/x, at least one point is NaN because a division by zero is not defined.
Message 15 of 15
(640 Views)
