Current DC wrong values with USB 6341
Hello everyone,
I am having a problems measuring current of a DC motor.
I need to measure with Labview the current of a motor that is working with 14V and 1 Ampere +/-. I need to measure this 1 ampere in Labview, but using a shunt resistance of 10miliohms i am displaying the values that you can see in the attached image that i have.
I am using a USB - 6341 and its only supports 10 volts input analog so i had to make a voltage divisor that i also have in the attached image. For Al1+/Al-) i measuring the voltage. For Al2+/Al2- I am mesuring current.
Could you please help with this. I don´t understand why I can´t measure the correct value.
Message 1 of 14
(4,335 Views)
Please post your LabVIEW code and a better image of your MAX setup.
Kind regards,
Rick Wagner
Message 2 of 14
(4,305 Views)
@giant_steps wrote:
Hello everyone,
What is wrong with the measured value? You are measuring voltage across a shunt resistor so you need to connect AI2-. Your measured value (with AI2- connected) is a noisy signal (which is normal when measuring motor current) with an average value close to 10 mv (absolute), this seems like the expected value for 1A in 10mohms. Just filter or average the output value for a cleaner result.
Ben64
Message 3 of 14
(4,298 Views)
My program is very simple. I just connected my DAQAssist with a waveform display to check the value i thought that would be enough. How could i filter or avarage my value to display the correct value of my mesurement?
thank you for your help,
Message 4 of 14
(4,292 Views)
Look at the VIs in the Waveform Measurements palette ( Waveform -> Analog Waveform -> Waveform Measurements). You can use Basic DC-RMS.vi or Avg DC-RMS.vi.
Ben64
Message 5 of 14
(4,286 Views)
I did it like you said but this way i don´t get any "wave" and I still "see" amplitudes moving around 0.034 and 0.035.
Is it normal or i am doing something wrong?
thanks ,
Tiago
Message 6 of 14
(4,276 Views)
thanks ,
Tiago
Hard to say if your doing something wrong without seeing what you're doing!
Ben64
Message 7 of 14
(4,270 Views)
Basicly i did this. :x
Thanks for your help
Message 8 of 14
(4,266 Views)
You're averaging a noisy signal on a few samples (100), try taking more sampling (like 1000) and you will have less amplitude variation.
Ben64
Message 9 of 14
(4,248 Views)
Still not working :x I thought that would be much easier to display current :x
Its suppose to get a current around miliampers in labview?
Message 10 of 14
(4,244 Views)
