Critical Bug Report: LabVIEW crashes when the Get Plot at Position method is called for a Graph in an unshown Tab page
The attached VI illustrates a bug I have been tracking down for a while. It appears to involve calling the XY Graph Invoke Node method "Get Plot at Position" when the graph is located in a tab that is not the front most (not a hidden tab, just a tab that is not currently shown as the top tab).
The example VI passes a (Inf. Inf) location because that's what my original code was doing, but this is irrelevant. Any other position will result in the exact same crash.
Note that the type of crash is different depending on whether you have a single plot or more in the graph.
The workaround is to use my little VIs here (which do a little bit more as a matter of fact, since it also includes looking at clicks in the legend area). I actually need to check these are the latest versions.
Tested in LV 2015 64 bit, but I suspect that this has been around for a while (I jsystematically replaced the hereforementioned VIs by this method after switching to LV 2015).
Message 1 of 12
(8,327 Views)
Hey X.,
I have reviewed your VI and reproduced the error on my end. I have filed a Corrective Action Request on the issue. Thank you for pointing this out.
Best Regards,
Andy M.
Message 2 of 12
(8,253 Views)
Thanks. What is the CAR number, so that we can keep an eye on it?
Message 3 of 12
(8,240 Views)
After so many years, and graphs and tab controls still causing problems together. There may be a lesson here -- wonder what it might be? Hmmmm...
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 12
(8,211 Views)
Mike...
Chilli can burn on both the way in and the way out?
Message 5 of 12
(8,206 Views)
Hello X.,
Sorry about that. It is Corrective Action Request #550336.
Best Regards,
Andy M.
Message 6 of 12
(8,176 Views)
There is another problem with the method, documented on the attached VI.
If the plot closest to the Mouse click has a single point, the method returns a Plot Number -1, which of course doesn't allow doing much down the road.
Add an extra point and things work fine.
Message 7 of 12
(7,927 Views)
For info, this bug has been submitted as CAR 587259 by NI support.
Message 8 of 12
(7,890 Views)
Mike...
IHateTabs
I think that is the lesson in a nutshell.  Tabs are containers, not controls! use them when you need a "Folded Container!"   Graphs are controls designed for Users to observe trends in data.  Tabs and Graphs should never be mixed!
I know somebody it going to mention the Windows Task Manager-  If things were working right, you would not know that thing existed!
So, Lesson: If you need a Tab to Graph data.... It is because the user and the data are not understanding each other! Better, debug the code befor shipping it!
"Should be" isn't "Is" -Jay
Message 9 of 12
(7,860 Views)
"Tabs and Graphs should never be mixed!  "
Please explain.
I have used tabs and charts in applications since tabs were first available. While I have seen some bugs associated with them being mixed, I aslo found work-arounds to avoid the worst bugs. Short of going through the extra work on using sub-panels, I think they are a great way of seperaiting a high level view of an application from detailed history or for that matter seperating configuration from operation views.
But you make that statement as if there is some fundemental conflict between using them together.
So please explain
Message 10 of 12
(7,847 Views)
