Creating reference to google earth activeX objects
hi everybody..
I am involved in a project the results of which i have to represent as placemarks in google earthI have created the kml files necessary.
I am trying to do it using theIApplicationGE class of the Google eartth application interfaceHowever everytime i try to create a referencei get error 97What is the correct way to create areference.
Mathew
(4,185 Views)
Accepted by lonewulf
hi lonewolf,
   Actually i had some VIs for google maps,you can navigate to the particular place if you the latitude and longitude of that place..Please find it in the attachments.
Thanks and regards,
srikrishnaNF
Srikrishna
(4,161 Views)
Hello Lonewolf,
Please check out the link . It gives information on the same
Many such example codes are available at ni.com/code.
https://forums.ni.com/t5/Example-Code/Embed-Google-Earth-in-Your-Application-Using-LabVIEW/ta-p/3528...
(4,135 Views)
