08-30-2021 01:23 PM
This may be a simple problem and I'm just not understanding some of the previous forum posts, but I'm trying to:
Following the solution in this post Solved: Using LabVIEW to compose JSON strings incrementally - NI Community I was able to build a JSON string. I was then trying to add to one of the JSON arrays by following the solution in this post Solved: Add object into JSON file - NI Community.
My code looks like this:
and I'm getting this output:
I want the JSON to read as follows:
When I try to run the code I get the following error:
Is there an obvious error to the path or the variable types that I am overlooking? Do I need to change input to the JSON string that I'm trying to add to a variant?
Thanks for the help.
Solved! Go to Solution.
08-31-2021 03:59 AM
