Creating an array to use as graph indeces.
Hello all.
I am sure this is probably a very basic question.
I am getting an array of length 1340- each value represents an intensity at a given pixel. Each pixel represents a wavelength in a y = mx + b form. So I initially had no problem using an intensity graph and setting the offset and multiplier within the graph's settings.
Now, however, I want to calculate the raman shift, which is more involved than the linear fit before:
I need to: create an array from 1 to 1340
Apply the y = mx + b to go from pixel length to wavelength
apply the above transformation (where lambda_ex is a constant) to each value.
Use these as an x axis to graph against my already acquired y-axis data.
Does anyone have any tips?
I did this but this results in an indicator array that I am not really able to further manipulate... Sorry, I am a noob to Labview
(411 Views)
You do not need to scale the axes.
Use the LabVIEW Help -->Find Examples... drop down menu to open the LabVIEW Example Finder and search for the "XY Graph Data Types.vi" VI.  It shows multiple ways to graph XY data.
(402 Views)
Hi sean,
This loop will NOT create the desired array of 1…1340 as "i" starts with 0 and will have the value 1339 in the last iteration…
Why don't you use basic math operations (like multiply and add) on your array? (Ever heard of "polymorphism" with respect to LabVIEW?)
What is "pixel length"?
(383 Views)
Hello all.
You seem to have a mix of several ambiguous problem and I cannot make sense of what you are saying.
  • An intensity graph is for data with two independent axis (e.g. a 2D array where the indices relate to X and Y and the value is Z.)
  • You talk about an array of length 1340, which is 1D and just requires a plain graph.
  • Pixels are in 2D units, so what is a "pixel" in your world?
  • Once you transform, the axis is no longer linear in lambda.
  • Maybe you could graph a suitable transform?
  • Maybe you could do a linear ramp of Raman shifts and remap by interpolating into your existing data
Please attach a simple example containing typical data. Everybody here know how a FOR loop looks like, no need to attach silly pictures.
(379 Views)
