07-24-2025 11:32 AM
Hello all.
I am sure this is probably a very basic question.
I am getting an array of length 1340- each value represents an intensity at a given pixel. Each pixel represents a wavelength in a y = mx + b form. So I initially had no problem using an intensity graph and setting the offset and multiplier within the graph's settings.
Now, however, I want to calculate the raman shift, which is more involved than the linear fit before:
I need to: create an array from 1 to 1340
Apply the y = mx + b to go from pixel length to wavelength
apply the above transformation (where lambda_ex is a constant) to each value.
Use these as an x axis to graph against my already acquired y-axis data.
Does anyone have any tips?
I did this but this results in an indicator array that I am not really able to further manipulate... Sorry, I am a noob to Labview
07-24-2025 11:53 AM
You do not need to scale the axes.
Use the LabVIEW Help -->Find Examples... drop down menu to open the LabVIEW Example Finder and search for the "XY Graph Data Types.vi" VI. It shows multiple ways to graph XY data.
07-24-2025 12:39 PM
Hi sean,
This loop will NOT create the desired array of 1…1340 as "i" starts with 0 and will have the value 1339 in the last iteration…
Why don't you use basic math operations (like multiply and add) on your array? (Ever heard of "polymorphism" with respect to LabVIEW?)
What is "pixel length"?
07-24-2025 12:48 PM - edited 07-24-2025 12:50 PM
Hello all.
You seem to have a mix of several ambiguous problem and I cannot make sense of what you are saying.
Please attach a simple example containing typical data. Everybody here know how a FOR loop looks like, no need to attach silly pictures.
