Creating a refnum for a specific type of control
Hi All,
I have attached a VI that I made, but not from scratch.  As near as I can tell, it is not possible to make this subVI from scratch because one cannot find a Dignum Refnum in any menu containing refnum's.  However, the edit>Create SubVI menu function was not only able to make a subVI for me, it was also able to magically create the refnum I needed in the first place (the one I needed to make the subVI from scratch).
This is not a huge question, but the whole thing took me an extra, and annoying, 0.5 hrs this morning because I insisted that if LabVIEW can create that refnum, so can I.  I was wrong.  Or was I?  What am I missing here?
(The reason I had to specifically use the DigNum RefNum is because a simple control reference doesn't have access to the text properties).
Cheers,
Brad
Message 1 of 9
(7,156 Views)
Hello
Hope this helps?
Andreas
There's three different kinds of people, those who can count, and those who can't.
Message 2 of 9
(7,149 Views)
I'm stuck on LV 8.0, so I can't see what you've done.
I succeeded with the subVI that I posted, but I want to know how to create such a control reference from scratch in order to achieve access to the text colors property of a generic property node once it is attached to this type of refnum.
Brad
Message 3 of 9
(7,135 Views)
Hi
I'm not at work right now so i can't convert my code for you. To create that CtlRefNum do the following:
1. Put a control ref. on the fron panel.
(right click on the ctlrefnum)
2. choose the class, gobject, control,numeric numeric.
3. choose type, digitaln it will now change its apperance.
4. choose to include data type, this is where you get that little orange star on the ctl.
I think this was the correct steps, but i'm not 100% sure.
Regards Andreas
Message 4 of 9
(7,125 Views)
I usually do it by creating a reference to the control I want, then right-clicking on the output of this reference and selecting create -> control. Voila, a refnum control that is the same type as the control. I just cut and paste this into the sub vi.
Message 5 of 9
(7,120 Views)
I used to use the sub-VI method to create the proper type of refum control.
I believe it was a past Nugget that showed me that if I did a "ctrl-drag" of a control ot the type I wanted onto a generic refnum control, the refnum would adapt.
First step
Ctrl-drag boolean onto refnum
drop and it adapts.
This feature was added in a recent version of LV. Not sure which.
Ben
Message Edited by Ben on 03-30-2007 02:56 PM
Message 6 of 9
(7,120 Views)
Thanks all.  That was very helpful.  Especially the nuggete - oh how we miss the nuggets...
Message 7 of 9
(7,076 Views)
"oh how we miss the nuggets..."
I'm dancing as fast as I can! Smiley Surprised
Ben
Message 8 of 9
(7,068 Views)
..and as a valuable bonus this method gives the refnum a name derived from the control's name. Like MyStartStop --> MyStartStop 2.
The other methods like the drag-drop gives it a generic name such Bool Refnum i.e. emphasis on the type rather than the control.
Would be nice if drag-drop into a Refnum worked in this sligthly more useful way. That it is a refnum is implicit in the appearence so this is not needed as part of the name.
Message 9 of 9
(5,119 Views)
