Creating a gear like customised indicator
Can anyone help me?
I want to create a cutomised inticator that resembles a gear and rotates when I update its position (degrees)
(2,885 Views)
Two options come to mind.
1)
You could use a Pict Ring and populate it with as many pictures as required to meet your resolution requirements.
2)
Use a Picture control and use the code that Christian posted here to rotate the image in the picture. Note: You can make the background of the picture trnaparent and with a properly masked image, render the transparent regions of the gear.
Ben
(2,882 Views)
This post (on LAVA) has some help making a steering-wheel control.  Seems that you could take the same approach.
http://forums.lavag.org/Need-help-to-create-a-steering-wheel-control-t12402.html
Jim
(2,848 Views)
