Creating a file with labview
Accepted by rohini_basu
Here you see a picture of my VI.
You can find the VIs on the Timing palette.
Remember Cunningham's Law
Message 11 of 15
(1,190 Views)
Yiiipppiiieeee, its done now. Thanks a lot. Actually I was trying with the write to lvm file and the merge blocks. Hence whenever I was trying to connect the strings with the input of the merge block I was getting an error message that the source is a string and the sink is a dynamic data.
Message 12 of 15
(1,184 Views)
*quote* Yiiipppiiieeee *unquote* I got my first kudo!!!
Message 13 of 15
(1,180 Views)
Here, have another! Smiley Wink
Message 14 of 15
(1,176 Views)
Hey thank you so much!
I think it's the same with Kudos as it is with millions. The first one is the hardest...
Message 15 of 15
(1,172 Views)
