Creating a delay in labview until a c program completes in system exec.vi without using "wait until completeion"
I want to run two related C programs. The second one reads a text file that the first created. So I need to wait until the first is completed.
I use "system exec.vi" and I know I can set "wait until completeion" to true, but this way I won't see the screen and the C program announcments. Someone has an idea?
(3,001 Views)
Hi Dror,
my idea: just wait for the text file created by the first C program. Check for the presence of this file (maybe using 'list directory') or check for the size of this file...
(2,999 Views)
Just use one of the System Exec outputs to create data flow.  For example, wire the Error Out from System Exec to a sequence structure and put some code in the structure.  That code will not execute until the system exec is completed.
- tbob
Inventor of the WORM Global
(2,965 Views)
Hi Gerdw
Good idea, it works
thanks
(2,937 Views)
