09-18-2013 10:43 AM
I have a question on a Sub-VI. I am driving from a memory array certain indicator property nodes at different offsets. For the reason of clutter on my top level, when driving many of these, can these go into a Sub-VI? I have tried to do this but it gives me many top level references stacked on each other. Not sure what its doing.
On the top level i wanted these indicators updated on an event change and would be the same in the Sub-VI.
i put in pic of the partial block diagram..
thanks
09-18-2013 10:45 AM - edited 09-18-2013 10:47 AM
Attached picture isn't visible (broken link).
Edited: also I would like to add, attaching your code (or may be a prototype code around your idea) will help us to understand the problem statement better.
09-18-2013 10:51 AM
here is the picture..
09-18-2013 12:42 PM - edited 09-18-2013 12:45 PM
You could get references to all of the controls on the main VI's front panel and operate on them:
You'll probably have to add logic to identify the particular controls you want to manipulate. You can do that with the Label property.
