Creating a Bracket
I am trying to build a race bracket that will follow the order of the attached picture. The picture and my code are for only 10 different contenders. Also attached is the text doc with the contenders initial qualifying times.
Here are the directions on how to run may code (to simulate the races I assigned random numbers to each contender):
Click:
1. Run race
2. Click next race
repeat until every one has raced
3. Click next round
repeat 1 and 2 until everyone has raced
4. Click next round
continue until the final race has been run
Thank You
Message 1 of 8
(5,997 Views)
Message 2 of 8
(5,993 Views)
I this just an announcement or are you having problems with your code? If you need help on a topic, please post your question.
Anna K.
Message 3 of 8
(5,933 Views)
Is there a way in labVIEW to create a Bracket so that the competitors follow the format of the picture that I posted?
Message 4 of 8
(5,892 Views)
you can use an event cass so that every time you hit the race button it will run the race and you can use string indicators to create a bracket look.
and than you can creat another event case so that when you press start a new race it jumps to the next two availible string indecators.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 5 of 8
(5,872 Views)
also instead of a array you could use a cluster and than convert it to an array when needed.
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 6 of 8
(5,860 Views)
here is the cluster I created hope it helps
Harold Timmis
htimmis@fit.edu
Orlando,Fl
Message 7 of 8
(5,823 Views)
For this type of display...
... i would use a Picture Control. See this thread for examples of using the Pciture Control.
If you get this working please post an example. It would be a nice addition to our collection of Picture Control Examples.
Have fun!
Ben
Message 8 of 8
(5,804 Views)
