Creating a 1/3 Octave Graph from Collected Sound Pressure Data
I was wondering if it is possible to create a 1/3 Octave band graph from previously collected sound pressure data. I managed to import my collected data into Labview using the "Read Delimited Spreadsheet VI". I have tried using the "SVPO Scale Voltage to EU VI" coupled with the "SVT Third-Octave Analysis VI" with my collected sound pressure data as the signal input but no Band Power Data is generated.
Please forgive me if I have made an obvious mistake. I have used Labview in the past but this type of analysis is fairly new to me. Any help from the community is greatly appreciated. I am using labview 2017.
Best Regards
(3,919 Views)
Do you get any error along your processing chain?
If you converted your spreadsheet data to a waveform (Wfm), have you checked that you got the correct dt value (1 / sample rate)?
Have you probed your data to verify its presence and validity where it is expected?
Any chance you could post your VI with associated data?
(3,856 Views)
Accepted by topic author 11gg
Hi LocalDSP
Thanks for responding to my question. I did not get an error message. It ran without issue and it was only plotting the first recorded data point in the series. I managed to find a solution on my own by saving the recorded data as a .wav file and saving the file in the Labview wave file directory. Using the "get wave" VI, I was able to successfully import all the recorded data. I was able to perform the desired sound metrics as a result.
The take away from this is to convert the recorded data into a .wav file. Importing raw data straight into the VI will not work in this scenario.
(3,843 Views)
