Creating Power point presentations from LabVIEW
I need to create a microsoft power point presentation from LabVIEW. Has any one worked with power point from labVIEW.
(3,208 Views)
Yes I have done PP in LV.
Quick suggestions to start.
1) Use activeX. Provided you do not try to use the events from PP you should be able to do most of what PP offers.
2) Before starting, make sure you have "help for VBA" installed. This can be isntalled from the MS source disks and doing a custom install. Without this, you will have no clue as to where to find things.
3) Check for VBA examples of what you are trying to do.
I have never composed a PP presenstation via LV. Check the VBA help to see if this is possible.
Ben
(3,208 Views)
