Creating LabVIEW Executable for sub-20 Multi Interface USB Adapter
Hi AA76,
Any luck with that solution?
James Mc
Ask me about Rust & NI Hardware
My writings are at https://www.wiresmithtech.com/devs/
Message 11 of 15
(3,990 Views)
Hi James
I tried it and unfortunately it is still not working. I was unable to copy the file "sub20dnc.dll" to the folder "c:\Windows\assembly"
Here is some information about this component
There are two ways to integrate the SUB-20 multi interface adapter into the NI LabView environment. First method is well known - direct calling MS Windows dynamic link libraries (dlls), i.e in order to use the sub20.dll API you should create a SUB-20 LV driver by defining all the SUB-20 API function calls and their parameters. We have an example of "direct sub20.dll calls" method available for download from our SUB-20 web page. This example initializes SUB-20 i2c and SPI interfaces.
The second method is much easier but requires NI LabView version 7 or latter. Starting from version 7 the NI LabView supports the Microsoft .NET technology. If you have LabView v7 or latter, we would recommend you to look into the easier way i.e. using SUB-20 .NET component - sub20dnc.dll. This component is a part of the regular installation package and located in the bin subdirectory of your SUB-20 installation directory. You can download the latest software from our SUB-20 web page as well. Among other examples this package contains SPI & I2C LabView sample vi's.
Is the following link has anything to do with this problem.
http://digital.ni.com/public.nsf/allkb/7BFBDA5EBF427FB38625769B005FE77B
Message 12 of 15
(3,985 Views)
Hi AA76,
That KB is designed for when you are producing the assemblies with LabVIEW so they can be added to the GAC although adding the Sub20 driver there would help I do not think we can follow these steps for it.
Using dependency walker http://www.dependencywalker.com/ we can see that the sub20dnc.dll still depends on the sub20.dll.  Try ensuring they are both present in the installation folder.
James Mc
Message 13 of 15
(3,956 Views)
HI.
There is thread discussing this issue
http://www.xdimax.net/forum/viewtopic.php?f=2&t=443
Message 14 of 15
(3,737 Views)
So did it finaly work?
Message 15 of 15
(3,672 Views)
