Created Subvi deos not work
I am new to programming in LabVIEW and I have tried to create a subvi in the Block Diagram. The Subvi works properly in the separate VI. when I dragged it to the Block Diagram, It can not be activated. That means I could not wire it to the input parameters. Also, the subvi creating option in the Edit button is not highlighted.  I attached the related photo below. I hope I could figure it out with your help.
Thanks.
(3,369 Views)
You need to connect your controls and indicators to the connector pane.  Before going any further, I suggest taking a look at the learning resources on the main page of this forum.
Bill
CLD
(Mid-Level minion.)
(3,352 Views)
Accepted by topic author Avral
Any VI can be a subVI, but you need to define the connector pane.
The "create subVI" menu requires that parts of the diagram is selected and it will wrap the selected code into a subVI, removing that part of the code from the main diagram and wrapping it into a subVI. This will already define the connectors too, and if the toplevel VI was working, the new code will work immediately (with some exceptions) and in the same way.
(3,336 Views)
Thanks guys, I figured it out. that is exactly the connector pane issues.
Best.
(3,310 Views)
