Create waveform from a set of points with differtent time intervals
I would like to create a waveform from a set of points like this
Time           Data
0                 0
0,5              1
0,6              2
1                 1
2                 0
5                 1
The problem is that the time interval between each points are not the same.
The only idea I found was to create a waveform for each doublet of points with the same rate (100ms) and than to append them together.
Does anybody have a better idea?
Risotto.
(3,729 Views)
Risotto,
XY charts are for such kind of waveform display.
got to Find Examples in LabVIEW and you will find a vi called xy graph. vi.
just take on array of time( x axis), an an array of data(y axis), bundle them and feed tem to xy graph
this should be of help to you.
(3,724 Views)
see attached pic
(3,722 Views)
Yes, this is good. But how can I create with this curve a waveform with a rate of 1Hz for example?
Risotto
(3,721 Views)
sorry Risotto, i misintepreted your query!
i am trying to come up with a possible way.
In meanwhile, let's hope others come up with a good approach
(3,717 Views)
You need to resample your unevenly spaced data.
Try here.
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=B45EACE3D93356A4E034080020E74861
Message Edited by unclebump on 09-15-2006 10:35 AM
(3,708 Views)
If you use a Wave From data type, re-sampling is not required.
When using a WF datatype the chart (graph) will pick-up the X value from the t0 of the waveform.
The trick is to just build an array of the single update value and make sure the t0 value is correct.
Re-create this example
and try it for yourself.
Ben
Note: make sure the data you pass is consistant with the data already displayed. If you post a t0 value that is older than what is already displayed, the chart will clear the display and start over.
Message Edited by Ben on 09-15-2006 11:49 AM
(3,693 Views)
