Create the 3d printer
Dear Labview community
I'm a Student . Right now , I got the machine with 3 axis and control by NI motion card (PCI 7350) and Prof told me to control it to draw something like 3d printer (using nozzle to extrude the material by Z axis)  . And  I already got the program and I wrote the question into the Labview . I hope Someone can share and help me to handle that
I really appreciate that . Once against , Thank you so much
Message 1 of 12
(7,227 Views)
What is your question? I would recommend you to start by figuring out what you want to do (why not use a flowchart if you find it hard visualize the steps) and come back here if you have any LV specfic questions.
Message 2 of 12
(7,213 Views)
Dear Hult
Right now . I want to move the motor to the position with the data was got by txt file . And I need to repeat that program with all of points into the file like gcode of CNC machine .
Thank you inadvance
Message 3 of 12
(7,162 Views)
So, where are you stuck?
Can you read the fle successfully?
Can you move the motor at all?
Can you move it to specific points?
As you've asked your question, the only way to help you is to write your entire application for you.  Nobody here is likely to do that.  You need to offer us something in this conversation so we know HOW to help you.  Let's start with where you're stuck and we can move forward from there.
Message 4 of 12
(7,151 Views)
Dear Nata
I already read the txt file and move the motor at all . but I don't know how can I repeat that program for all of the data into the txt file . I have just done that with only one point .
Message 5 of 12
(7,133 Views)
Hi tihai,
With all programming languages I have worked so far I used "loops" to repeat certain steps in a program. I think you can do the same with LabVIEW… (Yes, sarcasm!)
LabVIEW even goes one step further: you can have loops, which process all elements of an array automatically one after the other: it's called "autoindexing"!
As you are asking basic LabVIEW questions I recommend to take the beginner courses offered by NI for FREE on their website!
Message 6 of 12
(7,126 Views)
I know this is an old post but I would like to ask if there is any toolkit or add-on available which can directly read the gcodes and move the motor.
Kashish Dhal
Message 7 of 12
(6,577 Views)
Message 8 of 12
(6,559 Views)
@eltico wrote:
Hi Kashish,
Take a look at this thread
https://forums.ni.com/t5/Motion-Control-and-Motor-Drives/G-code-interpreter-using-LabVIEW-done/m-p/2...
PedroR
Eltico,
While that thread was ridiculous and gave me a good 5 minutes of laughs, it's not particularly helpful. The first post is some guy claiming he has developed something, followed by lots of people begging (and even "thirsting") for him to share it with them, with no response from the original poster.
Message 9 of 12
(6,555 Views)
I think the thread you shared was waste of 10 minutes.
Please share something that works.
Kashish Dhal
Message 10 of 12
(6,545 Views)
