Showing results forĀ
Search instead forĀ
Did you mean:Ā
Create logfile from three vis - data is sometimes missing
i have three measurement-vis running parallel in a loop
The three results are continuously saved in  global-array and also in a text-file.
The global-arrays has always all data but in the text-file is some data missing.
I think this is because the file is locked from one vi while the other vi wants to write his data.
What can i do here?
Something like writing data in a queue and another vi reads the queue and writes the file?
Or is there something like a "check if file is in use"-property? Then i could loop until unused before executing write?
(3,205 Views)
Try LabVIEW synchronization VIs. "Semaphores" would help you for prioritize the events.
You can find examples along with LabVIEW which will help in how to use it.
Step out of your comfort zone to experience the real you!
(3,202 Views)
Accepted by topic author OnlyOne
Yes, writing data to a queue is the perfect solution. Quick for the sender, the writer writes in it's own pace and no data missing.
/Y
Qestit Systems
Certified-LabVIEW-Developer
(3,194 Views)
I am not sure if using the semaphores would slow down my measuring.
If loop1 in the example would be my measure-vi1 and WriteToFile and If loop2 would be my measure-vi2 and WriteToFile .
Then loop2 is not exeuting while loop1 has locked the semaphore.
I can put the semaphore only around my WriteToFile-vi perhaps...
Or is this so fast that it will not be noticeable?
(3,193 Views)
Hi One,
use a queue to buffer all log data and just one additional loop that fetches the queue and writes to your text file.
Easy, fast, reliable…
(3,186 Views)
Sempaphores can slow down the measuring, as the loops will have to wait to get the semaphores, go with the queue. šŸ™‚
/Y
Qestit Systems
(3,182 Views)
