Create image with black and white patterns
Accepted by Nghtcrwlr
You are on the right track. When I asked about hte IMAQ VIs I meant the initial ones that generated the initial file. Those are the ones that are un-needed. See the VI I attached (downconverted to 2011).
Starting with an empty picture (white background by default) I draw my black rectangle. I then convert it into an image that is 500x500. Finally, I save the image as a png.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 11 of 13
(849 Views)
Thankyou mike!!
Yes now i get it what u meant about IMAQ..
Thanks alot!!
Nghtcwrlr
Message 12 of 13
(844 Views)
You're welcome - and thanks for the kudos.
Mike...
LabVIEW Champion
Message 13 of 13
(841 Views)
