Create exe with some vi files
I am using LabVIEW 2010
I am trying to build a "Main.vi" into an exe, in which this Main.vi needs to dynamically call two vi "1.vi" and "2.vi". I have put  into "always included" before building the exe. But after creating exe "1.vi" and "2.vi" don't run.
Message 1 of 16
(4,452 Views)
Hi Darkhan
If you are using dynamic calling, you need to ensure you get the correct path:
your path is probably broken/incorrect in the EXE.
use the "Application Path" to specify the path to the VI in your project in the development environment, then it sould work in the runtime environment!
(Path constant found on File I/O > File Constants Pallette)
Should work for all LabVIEW from 2009 onwards if I remember correctly.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2015 SP1, 2018SP1 & 2020 installed
Message 2 of 16
(4,431 Views)
Thank you for the answer and I apologize for my English. My LabVIEW program  work correctly. I have 2 vi: Monitoring.vi and Monitoring_of air.vi, when in labview I click button of monitoring will open Monitoring_of air.vi. But when I have created exe file only open start vi. Monitoring_of air.vi is ignored.
Message 3 of 16
(4,421 Views)
Your paths are absolute and point to a static location outside the EXE.
Inside the EXE, you should navigate using "Current VI Path" and strip the VI name, then add the sub-vi name (and path, depending on the EXE setup).
Norbert
Norbert
Expert: Geometry
Message 4 of 16
(4,415 Views)
Accepted by topic author Darkhan
Just to show what Norbert is saying.  You should get in the habit of using relative paths.  They will save you a lot of headaches down the road, especially if you are dynamically calling VIs inside of EXEs.
GCentral
Message 5 of 16
(4,397 Views)
Hi Darhan,
If you build up from the Applcation path you should be fine.. I rather suspect that the application path is "D:\monitoring2" in this case anyway.
(Look at the detail help to see how the application path is working.)
If you can get it working with the application path as a relative path in the development environment, your runtime should not crash!
James
Message 6 of 16
(4,391 Views)
Thank you very much!!!!
I've got it!
Message 7 of 16
(4,381 Views)
Hi!
I have created exe file, but open button of my report (Word) don't work. I used "Current VI Path". In labview this button is working.
Thank you!
Message 8 of 16
(4,309 Views)
Message 9 of 16
(4,308 Views)
If moving outside of the EXE, you should use "Application Directory" instead of Current VI Path. This ensures that you leave the EXE without the need to track "Strip Path" on your own.
Norbert
Norbert
Expert: Geometry
Message 10 of 16
(4,279 Views)
