Create array with for loop
Hello.
Stupid question, but i can't do it myself.
I receive scalar byte data from com port in main while loop and want to make 1D array with adjustable size for further filtering and so on. Simple "for loop" with indexed output makes me array with all the same elements.
Can anyone tells me how can i make this?
Thank you.
Message 1 of 34
(5,789 Views)
Build array with a shift register. This would be in your main acquisition loop. It does sound like you could make use of the pt-by-pt functions, though.
Message 2 of 34
(5,777 Views)
Can i tell more about you solution? Shift registers in main loop or in for loop? Or can you show me example, please
Message 3 of 34
(5,771 Views)
In the main loop where you are doing the scalar acquisition. You need to post your VI if you need help.
Message 4 of 34
(5,769 Views)
Ok, thank you very much. I'll try this and post if there will be questions. Thank you.
Message 5 of 34
(5,748 Views)
Why can't you use string to byte array function.
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 6 of 34
(5,724 Views)
First, sorry for my english.
I receive bytes every 10ms and want to use filters and other processing. So, thats why i want to create 1D array with adjustable size. In other words, "stacking" 8 (or 4 or 100) bytes to 1D array. I know, that this is simple, but have a "wall" in my head )
Message 7 of 34
(5,705 Views)
Try this & let me know.
--Ranjeet
Message 8 of 34
(5,698 Views)
Ok, i was try your example. I'm replace random generatro with input from visa and see that all elements of array are identical...
Here is my VI. First part of it is simply for formatt input from COM port - take two bytes from array and make word.
Message 9 of 34
(5,694 Views)
2011 compatible VI please
--Ranjeet
Message 10 of 34
(5,690 Views)
