Create array from microsoft office spreadsheet 11
Hello.... I did create a active X microsoft office spreadsheet 11 on myfront panel, because I want to paste data copied from excel in this spreadsheet in labview. I got success doing this, but I want to create a labview array with this data and I don't know how can I do this, using property node or invoke node. What method of invoke node ou property node I should use?
The data that will be pasted in labview, will have only two columns. So, I will need to create a 2D array.
Dan07
(3,585 Views)
Accepted by dan07
Hi Dan07,
see this link. You will find a lot of functions to work with excel.
Hope it helps.
Mike
(3,558 Views)
Hi Mike,
Your link suggestion helped me a lot...
Dan07
(3,524 Views)
