Create application with multiple LLBs
I asked how to add files to the Always Include list.  My Always Include is greyed out.
File attached.
Message 11 of 39
(1,076 Views)
Why does your file list only have one VI? Did you add all the other VIs to the project first?
Message 12 of 39
(1,072 Views)
All of the VIs I use are in the Project Dependencies list. See attached.
Message 13 of 39
(1,069 Views)
Anything that's dynamically loaded needs to be added to the Always include list, since LV doesn't know about it at compile time.
Qestit Systems
Certified-LabVIEW-Developer
Message 14 of 39
(1,033 Views)
The problem is I can't seem to add anything to the always include list.  All options are greyed out. See attached.  I don't have any dynamically loaded VIs, they are all statically linked subVIs.... all in different LLBs.
Message 15 of 39
(1,030 Views)
You might need to drag them to the project first from the Dependency list.
Qestit Systems
Message 16 of 39
(1,025 Views)
I dragged all of the dependencies up to the project level. Added all of the VIs to the Always Include list. Still when I run the executable the pink toolbar at the top does not display.
Message 17 of 39
(1,014 Views)
You keep throwing BMPs at us.
The toolbar VI will not be in the dependencies if it is exclusively called via a path, it will also have a different relative path when called inside the runtime.
Can you include some error handing to see what the runtime thinks when the toolbar is called?
Can you remove all these "always include" items again and show is the built preview instead?
Message 18 of 39
(1,009 Views)
I'm not sure how to add error handling... I've got the error cluster wired to/from each subVI. I've got a tab control on the front panel called Errors that display the contents of the error cluster. There are no errors. The executable appears to be working because when I click the DONE button, the application closes, as expected.
Also, what is built preview?
Message 19 of 39
(996 Views)
Message 20 of 39
(991 Views)
