Create an image indicator
Hi
I am looking at the NI trigger camera example and try to learn. However, I get into one problem. When I right click the Grab function and click create an indicator for the image output, the front panel does not give me a picture. Instead, it is a grey out text indicator with the label "I/O".
So my question is how to create an image indicator to show image? I also see another example with toolbars besides the image indicator. How can I get that?
(5,062 Views)
Accepted by Jacobier
Indicators are on the palette of the front panel. Place one and you'll get a corresponding terminal on the diagram. Connect it to your data source.
(5,052 Views)
So does it mean if I create one from the block diagram, I can't change the indicator type on the front panel afterward?
(5,045 Views)
Well, yes, but that would be a detour. You can go to the front panel and right-click...replace the wrong indicator with the desired one.
(5,036 Views)
Note, whenever you create a control/indicator for a subVI terminal on the block diagram, you'll get whatever is used on that subVI. It does not make sense to have images on panels nobody ever looks at.
(5,034 Views)
