Create a customized boolean indicator
I have developed an application using a state machine approach. When i run the application, I have a boolean LED indicator which glows green when its ON and red while its OFF. I need to create a customized thick line(as indicator) which behaves like a Boolean LED Indicator. Any help would be greatly appreciated.
KM
(2,987 Views)
Accepted by KevinKM
Can you define "Behaves like a boolean indicator"?
You could always just take a square LED and play with the dimensions and colors until it is shaped like a line and has the same off color as the background.
(2,970 Views)
How about Square LED??
uday
(2,947 Views)
